JD317
Dave Slaunwhite
06-29-2000 14:01:23
I have a John Deere 317 somewhere around a 1978-80 model. It is not charging and I was wondering if there was anything easy I can check or do I head to the Mag.
Steevereno
06-30-2000 18:40:36
 Re: JD317 in reply to Dave Slaunwhite, 06-29-2000 14:01:23
Using a multi meter put one lead on each of the out side terminals of the regulator and at full throttle you should get 20 to 35 VAC. If that is good check the center terminal for about 12 to 14 VDC. Check all connections (including the key switch for corrosion.
Spokerd1
06-30-2000 15:11:41
Check your Regulator. That is what I found most of the times causing the charging problem. Very seldom did the ciols go bad which acted like an Alternator. You might have a bad connection also. Check that first.
