David, the slot in the gear & the shaft is called the "keyway".. The actual key [half moon shaped] is called a "Woodruff key". ~Those Woodruff keys can be obtained from most good hardware stores, auto parts stores, or a Deere dealer.. Just take the old one along & match the size. ~Now here's the problems you will probably run into,, In most cases if the key is worn so is the slot in the shaft & gear.. A new key will probably still allow some slop & that will allow the gear to work on the shaft & wear a new key in no time.. ~What you will probably have to do is get the next thickest key & either file it to fit the gear & shaft slot or use a small grinder or file & make the gear slot wider to fit the new wider key. Your easiest way is then to file the shaft side of the new key to fit the shaft slot. ~You will probably also find that the gear is a loose fit on the shaft [it should be a press fit].. If that gear is too loose it will allow the key to wear quickly.. Either a new gear will be required, or using something like Loc-Tite quick metal or shaft & bearing mount will sometimes allow the gear to tighten up on the shaft.. [email protected]
