Fuel gauge not working
Phil
06-27-2000 19:03:43
The fuel gauge on my 4020D is not working. Is there a way I can test to determine if it is the gauge that is broken or the sending unit?
Thanks,
Phil
twopop
06-27-2000 19:44:06
 Re: Fuel gauge not working in reply to Phil, 06-27-2000 19:03:43
take the wire off at the sending unit,with the ignition on test wire with a test light,you should get a slight glow in the light.if you dont have power there check guage on both terminals to insure power going thru guage.ground out wire against body to see if the guage moves.if you have power as you should,if the guage moves the sener is bad if not the guage is bad
