B Carburator: Main Jet
Jimmy T
06-26-2000 21:38:58
I have a carburator off of a 1936 "B" that is being cleaned very simuliar to the discussion on "B carb" posted on June 09. My problem is the main jet will not break loose from the casting port. Appearently, the main jet is held in place with a spring. This indicates the jet should not be a
press fit into the casting. I've tried everything from soaking the entire casting in carburator cleaner (Berryman's B-9 Chem-dip) to mechanically pulling the jet out with a piece of althread through the center and jam nuts on both ends (easy out tool). I suspect there must be a thick layer of varnish holding the jet in place. The main objective is to not destroy this part if at all possible. Tapping threads in the bottom of the jet is one suggestion that has been made. But, I would imagine this would change the characteristics of the fuel mixture. Plus, the threads would strip out as tight as this part is held in place. I would appreciate some input.
Jimmy "T"
Jimmy T
06-27-2000 21:09:37
 Re: B Carburator: Main Jet in reply to Jimmy T, 06-26-2000 21:38:58
Thank you gentlemen for taking the time to respond to my question. Keep up the good work, you make a great team! Jimmy "T"
clooney
06-27-2000 16:20:12
Jimmy, follow Chucks advice. I have pulled many DLTX "nozzles" that way & haven't found one that won't come out yet.
David
06-27-2000 14:20:53
Check out the site below for a description of using a slide-hammer to remove the nozzle.
www.shaysnet.com/~rainbow/Manual.html
Be sure the "M" is capitalized
BMAN
06-27-2000 05:14:50
I heat the area around the nozzle with a torch. Let it cool and then try threading the bottom and pulling it out. If there's a lot of rust in the way I sandblast that area first.
Chuck
06-27-2000 04:28:26
have pulled many of these. Thread the bottom and put bolt in about 1/2 inch and put vice grips and rap the vice grips with a hammer knocking it out. You don't want to damage the throat side of the jet but the threads want hurt anything. Also I'd recommend that you get a gas jet to replace any way as you mixture will be way to rich with the all fuel jet.
