JD60 with Behlen power steering unit; need repair!
Farmer Tom
06-26-2000 07:27:54
My 60 has a Behlen (Columbus Nebraska) add on power steering unit. The steering rod shaft seal (steering wheel input side)is leaking! Anybody got any ideas where to get this repaired? Suggestions appreciated.
Thanks.
Jim
06-26-2000 20:47:41
 Re: JD60 with Behlen power steering unit; need repair! in reply to Farmer Tom, 06-26-2000 07:27:54
Some of the parts are available from Case IH for a 400 or 450 Farmall. The gaskets to adjust the spool aren't available ,The gaskets to adjust the gears and the o-rings on each end and the seals are available. The 450 Farmall I&T manual has a section on the Behlen pump and should help you get threw a rebuild.
dave g
06-26-2000 17:03:43
If you're good mechanically, you might be able to build up the shaft with JB Weld, if you can get it apart and can't get a new seal.
