John Deere 60 throttle
Philip Croff
06-25-2000 11:13:30
I was going down the road in 6th gear with my John Deere 60, and running near full throttle. But the throttle lever will slowly fall back, causing the RPMs of the engine to slow, causing the entire tractor to slow. Hoe can this be fixed? I had to hold the throttle forward.
buckeye al
06-26-2000 14:47:48
 Re: John Deere 60 throttle in reply to Philip Croff, 06-25-2000 11:13:30
Had this same problem on my 70D some 12 years ago. THe other guys are correct. That will very likely and usually does work. Just in case it does not, here's what worked for me. I removed the throttle lever unit from the dash, disassembled it & found the lining was simply worn to small crumbs. I cleaned up the base of the lever & used a 2 part epoxy type glue to glue a piece of new band brake lining to it.
BigJ
06-26-2000 10:23:22
I had the same problem with my 70 and just tightening the nut on the inside of the throttle lever fixed it right up.
Bob
06-25-2000 12:51:45
under the hood behind the throttle lever there is a brake lining for the throttle lever. just tighten the nut that has the spring under it to put more tension on the throttle lever brake.
Bob
