John Deere 60 first reduction gear
Philip Croff
06-25-2000 11:10:06
How do you check the oil in the first reduction gear of a John Deere 60? The one under the belt pulley is for the engine and crankcase. The first reduction gear is the small filler cap by the operator's platform.
clooney
06-25-2000 13:49:08
 Re: John Deere 60 first reduction gear in reply to Philip Croff, 06-25-2000 11:10:06
Philip, the 1st reduction case is kept filled by the transmission gears rotating & moving oil into it. The reason they have you fill it when you change the trans oil is that it takes time for the trans to fill it while running. If you really want to check it put a container under the 1st reduction case drain plug & drain it, measure it then pour it back in. Should be about 1-2 qts.
