I don't think it is a loose flywheel, which is there all the time, especially when the tractor is under load. A loose flywheel is easy to diagnose fron the tractor seat, with engine off, engage clutch, and rock the lever forward and back, without disengaging the clutch. The excessive end play will be very apparent (just watch the pulley move in and out axially) if the flywheel is or has been loose for some time. She'll really talk to you if you lock the brakes and slowly load her down. If the hitch assenbly is loose(4 bolts underneath into the main case), it could make a clunk sound when the load coasted forward, as trailers often do. I once had the entire hitch assy fall off while I was plowing....not tough to fix, but it's embarassing ! My suspicion is that you have one or both brake shaft bushings worn. Our '48 A had this, and as you would drive at higher speeds (like hoeing in 5th), the slop in the brake shaft to bushing would allow the brake driven gear to walk up the bull gear tooth, then as the shaft would attempt to stop this travel, it would be forced to "pop" back down into the bull gear groove. Eventually, the gear on the brake shaft split in two, which would have been fairly easy to repair, but it fell into the right side bull gear, and when it came around to the differential, it broke the main case quill on the right side (the one that is cast into the case), and old S/N 595751 was no more. I bought another A with a bad crank, and put the good engine in this tractor. Moral of the story: If you can determine which side it is coming from, pull the brake assy out far enough to clear the teeth of the bull gear, and then test it. If no noise, that's the culprit. But find it out and fix it before something catastrophic occurs. Frank-in-Tallahassee 70 D // 855
