John Deere 60 oil
Philip Croff
06-23-2000 06:44:44
On the 60, isn't the engine oil the same that does in the crankcase? On top by the pulley, there are 2 filling caps. One is big, one is small. Which one do you use? I can't find the little one in the manual. Don't you put in just 1 oil for both the engine and transmission?
Mike Aylward
06-23-2000 09:21:43
 Re: John Deere 60 oil in reply to Philip Croff, 06-23-2000 06:44:44
Phillip, the large filler above the pulley is for the crankcase. The smaller one behind it, which is a pipe plug, is for the first reduction gear cover only. You will use about 1 1/2 quarts of gear lube in the reduction gear cover, and 8 quarts of motor oil in the crankcase. This is all mentioned in your 60 Operator's Manual. Hope this helps. Mike
