Help John Deere Model 2010 Hydralics
Rich
06-22-2000 17:08:26
Ever since I've had my John Deere Model 2010 the hydralic lifts have been jerking. Finally the hydalics quit altogether. I added fluid and it started working again. The hydralics quit again and when I opened the plug to add more fluid, the fluid started gushing back out the fill hole. Any suggestions would be apprecitated.
ben
06-25-2000 07:09:25
 Re: Help John Deere Model 2010 Hydralics in reply to Rich, 06-22-2000 17:08:26
rich. there is no filter on the 2010 but ther is a screen on rigbt side of tran. housing 3 bolts behind the brake rod this screen become plugs no hy it is metal so clean and reuse you have to drain the hy. fluid 15 gallon i think
Torinda
06-23-2000 06:08:11
there is a screen in the rear end that is probably plugged up. the oil is sucked thru the screen and then pumped thru the filter by the trans hyd. pump. I dont know where the screen is on the 2010 but deere can tell you
DHunter
06-22-2000 19:42:53
I don't know anything about the 2010 hydraulic system but it sounds like the fluid to the pump is being restricted and the pump is cavitating. Check the filter which probably is plugged.
