630 steering
OkieBill
06-21-2000 20:05:02
My 630 with roll-o-matic seems to be developing some directional "looseness" in the front wheels. Not heading for the ditch yet but would rather fix it before it gets that bad if possible. Thanks for your help!
dave g
06-21-2000 20:29:26
 Re: 630 steering in reply to OkieBill, 06-21-2000 20:05:02
The problem you seem to be describing seems to be flutter, which is the result of too much oil flow. IF the power steering unit is the same as on a 60, you should just have to adjust the flow control valve. Take off the front hood, and it should be the farthest nut on the pulley side of the tractor, just off the worm gear housing. There will probably be a regular 3/8 nut, then one about an inch long that's capped on the end. Take the long nut off, loosen the other nut, then turn the screw inward or outward until it steers the easiest without fluttering. This is only if the unit is the same as a late 60, and it's late, so maybe my descriptions leave a bit to be desired. Feel free to e-mail me, because I've done a lot of work on a 60 pwr steering system.
Haybaler
06-23-2000 05:56:23
 Re: Re: 630 steering in reply to dave g, 06-21-2000 20:29:26
Just a point, check the four bolts that hold the rollamatic pedastal on under the tractor. They can come loose and cause some MAJOR problems. My 2 bits. HB
