430 continues to run
Charles Jackson
06-21-2000 08:55:12
It takes my 430 too long to stop. (I understand the heavy flywheel contributes to that). The last few turns in runs backwards and blows oil from the
air cleaner. What to correct? Thanks
Prune Picker
06-22-2000 17:26:59
 Re: 430 continues to run in reply to Charles Jackson, 06-21-2000 08:55:12
Charles, does the motor speed up fast or does the RPM rise slowly? I have a 420 that the timing was off, which used to do the same thing. Slow to speed up and slow to idle down... then off. These things are really easy to time. Suggest you check the timing.
