G hyd
mike
06-20-2000 01:21:50
Can you pull hyd pump w/out removing pto unit? Or do you have to pull whole piece w/ pto and hyd controls and all? The bottom of pump body is cracked. ( water froze?) Thanks Mike
Gman
06-20-2000 22:18:47
 Re: G hyd in reply to mike, 06-20-2000 01:21:50
Mike I had the same thing happen to one of my "G"s It's been a while ago,but drain oil and remove the pto seal assembley,I'mm doing this from memory,then remove snap ring. Take a plastic mallet and start tapping till it starts to move,all surfaces are machine faced meaning no gaskets.The center section is where the crack is.You can't weld it cause heat will ditort it so locate crack take a die grinder an cut in to crack,if Im not mistaken it usualy cracks in bolt hole .After you have notched it apply a little J.B. Weld file down fairly close then hone with a knife sharping store till smooth then reassemble,do all this with your fingers crossed that it holds. I lucked in on a N.O.S. part. Gman
