2020/2010
Matthew H
11-09-2003 07:45:48
I'm looking at purchasing a larger tractor. Either a 2020 or a 2010, both are gas. I'm currently running a 1020D and a 1010G. I know about the problems with the 1010 and the 2010, but I love the 1010. The 2020 is more expensive, and it does not have any Hydralic Outlets. I would like to run it with a #48 loader. How hard would it be to add Outlets, & is this the best option between the two?
firedog
11-11-2003 13:46:34
 Re: 2020/2010 in reply to Matthew H, 11-09-2003 07:45:48
Mathhew,
The 2010 and 2020 were totally different tractors.
The 2010s were made 1961-1965. 2020s were later and much more sevicible. You should be able to plumb the loader up
firedog
Dan
11-09-2003 18:02:04
People either swear by or swear at the 2010. The 2020 is at most a very distant cousin to the 2010. as I remember the 2020 had the hydraulic oil filter below the operator platform. For a loader you can get a special filter cover with a fitting on it to run the return from the loader. You tap into a pressure line for the other side. and use loader valves. For a loacer on these you need side frames, steel plates that go from front of engine to rear of it. Not sure I remember how the 48 mounts on one of these. Think in the long run the 2020 will be your best bet.
