420 Hood Warped
Henry J
11-09-2003 06:34:37
I have got to start moving on my 420 sheet metal. The hood has got me bamboozeled. This tractor has been on fire, and was done medium rare lol. The top of the hood is straight and it is also straight on both sides at the top. However if you sight down the metal on both sides of the bottom of it it is bowed. A straight edge shows about 3/16 inch bow. Anyone out there seen this cured and know of an approach to taking this bow out? I have never worked on, seen it done, or heard of a way of curing a sheet metal defect of this length before.
Wayne in Tn.
11-09-2003 09:02:29
 Re: 420 Hood Warped in reply to Henry J, 11-09-2003 06:34:37
Henry J. You have found a common problem with those 40 and 420 hoods. First go to the tractor and run a string from front to rear, where the hood pin receptacles are, make sure the middle one is in line with the front and back ones. If not, beat,bend or pull until you get them all lined up perfectly. As to repairing the hood, about the only way is to start with a body hammer, with the hood on concrete or a good flat surface, and hammer it from the inside until you get it straight with a straight-edge. Then you will have to give the outside a complete coat of body filler and use a 16 inch air file to keep it straight.
Steve Crum
11-09-2003 20:57:04
 Re: Re: 420 Hood Warped in reply to Wayne in Tn., 11-09-2003 09:02:29
DON'T wear your bi-focals like I did! while performing Wayne's operation.
