Re
Torque Head gasket ??
al
06-12-2000 14:32:32
Is it necessary to retorque headbolts after running the tractor? If so what is the accepted procedure? Temp, time etc....
Thanks
Brendon
06-15-2000 00:29:02
 Re: Re - Torque Head gasket ?? in reply to al, 06-12-2000 14:32:32
What engine/tractor is this on? It makes a difference
Thanks
Brendon
DougS
06-12-2000 16:05:44
Al..It is not always necessary, but it cannot hurt. Just get it up to normal operating temp and pull the stud pattern again. Do you want some 6.25" Cat pistons and rings? Brand new, I will not use them, give me a note if interested. Doug in Tx
G Taylor
06-14-2000 20:15:12
 Re: Re: Re - Torque Head gasket ?? in reply to DougS, 06-12-2000 16:05:44
If your engine has head bolts that extend into the water jacket don't retorque them. The sealant you put on around the threads will leak.
