730 Starter
Haybaler
06-12-2000 10:29:20
Starter turns tractor over about 2 times then kicks out and freewheels. Starter rebuilt and battery is hot. Ring gear on flywheel is good. Tried adjusting linkage on starter, but didn't help (also freely admit don't know if I did it right). Anybody else had this problem and so how did you fix it?? Luckily tractor starts fairly easily, or would be a real pain!! Thanx in advance. HB
Brian
06-13-2000 12:20:50
 Re: 730 Starter in reply to Haybaler, 06-12-2000 10:29:20
Is this Gas or Diesel? I have had a hard time keeping my 730 diesel starting correctly. The battery cables for a diesel (24 volts) need to be in top notch shape. Each spring I must clean the cable ends and clean corrosion. I am going to change them when I cannot clean them to satisfactorly start the tractor. New cables from Deere run over $100. If you are sure your cables are good and a good battery, I would point to the starter.
Gator
06-13-2000 21:01:54
 Re: Re: 730 Starter in reply to Brian, 06-13-2000 12:20:50
Ihad this same problem on my 630 gas. Not only did I find one of the 6 volt batteries was weak but I had to have the starter rebuilt as there wasn't enough power to fully engage and operate the starter motor. Hope this helps.
