60 pwr steering spindle
dave g
06-10-2000 19:40:18
how does the bottom spindle bearing on a 1956 60 with power steering get lubrication? The bearing had power steering fluid on it, but when I put new seals in, there doesn't seem to be a way for oil to get to it. Is it supposed to be greased?
clooney
06-11-2000 04:52:57
 Re: 60 pwr steering spindle in reply to dave g, 06-10-2000 19:40:18
Dave, you will have to pull the grille then remove the pipe plug (on the r/h side of the lower quill) then install a grease fitting ) it should be greased once a year.(note: do not over grease it) If you can't find it, E-Mail me & I will send you a picture.
dave g
06-11-2000 11:31:26
 Re: Re: 60 pwr steering spindle in reply to clooney, 06-11-2000 04:52:57
Thanks. That's what I thought, but I have it apart and there doesn't seem to be any evidence of grease, but the bearing is good...probably all the oil that leaked out over the years....
