Hydraulics 1949 JD M
Tom Dykes
06-09-2000 15:10:55
I have the JD touch-a-matic system on my "M". Single piston. The lift arms jerk up and down when weight is applied. I have replaced the seals on the cylinder head and the piston, because it previously did not work. What is wrong? Also need a recommendation for a good sealent, the front gasket continues to leak.
Farmboy
06-10-2000 19:59:49
 Re: Hydraulics 1949 JD M in reply to Tom Dykes, 06-09-2000 15:10:55
Hey Tom,
sounds like the check valve pushrod is out of adjustment. You get to it by removing the round plug on the left side. It is held in place by a snap ring and ussually has a threaded hole to use a bolt to pull it out. I would suggest getting a copyof an I.T. manual before taking it apart to see the order of parts. It uses shims that look like washers to adjust the length of the rod. What it sounds like is happening is that just as the controlvalve reaches the hold position, it opens the checkvalve and drops the load, then the controlvalve applies pressure and starts the bouncing cycle over and over. I don't remeber for sure but think that it needs a shim removed to remedy the problem, if I have it backward it will bounce more and just do opposite and add one extra. Hope this helps
Farmboy
