3020 load shaft
RCH
06-09-2000 08:02:48
I have to replace the seals on the load shaft annually and the tractor is not used all the time. ( I think that is what it is called,,, the sensing shaft for the 3 pt. hitch
(Late model 3020) These seal should not go that fast. What am I missing? the shaft looks good in that there is no scatches or scuffs where the seal sits. Any suggestions would be helpful..
Big Jake
06-13-2000 09:56:07
 Re: 3020 load shaft in reply to RCH, 06-09-2000 08:02:48
Link
Jim
06-09-2000 21:49:09
Do you know what time it is when a John Deere load control shaft seal stop leaking?
The answer is : time to put in more oil
Gurry
06-09-2000 10:10:56
It sounds to me like you should get an Allis Chalmers
Brady
06-09-2000 18:44:04
 Re: Re: 3020 load shaft in reply to Gurry, 06-09-2000 10:10:56
Yeah buy an Allis Chalmers, it'll make you a good mechanic, worked for me.
RCH
06-09-2000 11:03:49
Don't think so! J.D.3020 It even has green paint on it.
River Dale Farms
06-09-2000 12:47:29
 Re: Re: Re: 3020 load shaft in reply to RCH, 06-09-2000 11:03:49
J.D. load shaft seals that we replace are never back for the same repair. Call us at 920 295 3278, or e-mail at [email protected]
Joel
06-09-2000 14:05:43
 Re: Re: Re: Re: 3020 load shaft in reply to River Dale Farms, 06-09-2000 12:47:29
You need to make sure all the side to side play is taken out Deere has spacers to put between the yoke and the casting had the same problem on a 4020 -replaced everything soon it was leaking again. Then used the spacers put in new seals end of problem. Also recommend updating the inner bushings with one that has an O-ring in it Deere has that also.
