B carb.
Robert
06-09-2000 07:53:14
I have a '42 B since the winter it starts good but will not idle without 1/2 choke. You can play with the idle needle all you like and doesn't change a thing. I have removed carb and cleaned all ports and channels but no better. Any suggestions?
clooney
06-10-2000 05:13:25
 Re: B carb. in reply to Robert, 06-09-2000 07:53:14
third party image
Robert, I forgot a very important little hole on my post from last night (long day I guess) pay attention to the little hole labled "fuel enters idle system here"
Jim from Stonepile
06-09-2000 21:56:51
clooney and DougS are right. I have found that 3 times is a charm on these carbs! Seems as though you manage to miss 1 little thing! clooney saved me a lot of unessesary work last fall on a '52 B that I had cleaned twice. Good luck- JIM
missuri mark
06-09-2000 20:15:36
Robert's carburetor is the place to go. I think they will answer all ? .www.robertscarbrepair.com
clooney
06-09-2000 18:14:44
Robert, you will have to re-clean the idle passages to get that carb to work correctly. There is a little passage on the bottom of the idle screw well that sometimes rusts shut. You will have to look very closely to find it, either drill it open or try to run a piece of stiff wire through it. There are also little holes in the side of the throttle bore that tend to plug up, they are in the side of the throttle bore on either side of the throttle plate, you will probably have to remove the throttle plate to see them. Click on the "IDLE CIRCUIT" link below to view passages.
clooney
06-09-2000 18:17:01
 Re: Re: B carb. in reply to clooney, 06-09-2000 18:14:44
clooney
06-09-2000 18:24:38
 Re: Re: Re: B carb. in reply to clooney, 06-09-2000 18:17:01
third party image
Am-Having trouble getting his link to work
DougS
06-09-2000 16:37:22
If I said it once, I have said it 100 times, your carb is dirty! Anytime you have to use the choke to make these old machines idle, and twisting the idle adjustment just does not do a thing, you have not done your housekeeping in those small ports and passageways in the carb. Go back and do it again, and I mean more than B12 Chemtool and compressed air. This calls for small wire probes and small drills. Remove all plugs and get to scrubbing! Doug in Tx
