Anyone ever heard of JD 1620?
Tom
11-08-2003 22:07:24
Have you ever heard of a JD model 1620? I live in Middle Tennessee. A guy near here has a JD 1620 for sale. I wanted to do some research on this model before I talked to the guy, but I can't find any info on that model. Do you have any idea why?
Thanks for any advice you can give me.
Tom
Tom
11-10-2003 10:06:56
 Re: Anyone ever heard of JD 1620? in reply to Tom, 11-08-2003 22:07:24
Hi All,
Thanks again for all of your help. I went to the tractor today, and sure enough, it's not a 1620 - it's an 1120. Someone had repainted the hood at some time in the past and had stenciled on the wrong number. I found the serial tag on the right front rail. It is an 1120, for sure.
The tractor hasn't been moved for at least two years. All four tires are shot. It doesn't have power steering. It has a hand-made cage over the seating area, but it wouldn't provide any protection in a roll-over.
The guy wants $4,500.00. For it. I don't think that's a very good price considering the condition of the tractor and the risk of further problems since it isn't running now and hasn't been run for a couple of years. I think I'll pass on it.
Thanks again,
Tom
720Deere
11-09-2003 08:49:19
If there ever was such a thing, John Deere won't fess up to it. There is no 1620 tractor listed in the online parts catalogs.
Leroy
11-09-2003 08:40:36
Would it be a 2 cylinder 620 with a typo?
420 TEE
11-09-2003 07:53:20
Tom, You mentioned you live in middle TN. Where abouts? I'm in Pleasant View.
Tom
11-09-2003 18:57:47
 Re: Re: Anyone ever heard of JD 1620? in reply to 420 TEE, 11-09-2003 07:53:20
Hello 420 TEE,
I live about 40 miles south of Nashville. It's near Spring Hill but even closer to the thriving metropolis of Theta. I have 150 acres of hard-scrabble land on steep hills. Not worth a hoot for row-cropping, but good permanent pasture for cattle. I raise grade Angus and have a couple of horses. I love the place.
Thanks for your note.
Tom
will
11-11-2003 22:26:13
 Re: Re: Re: Anyone ever heard of JD 1620? in reply to Tom, 11-09-2003 18:57:47
Good to see some local folks on the board. I live on the Hickman-Maury County line in Shady Grove. My father formerly farmed a few hundred acres of farm on B Dodson road near the Carters Creek Pike which is the Carl Baker farm. We often stopped at the Theta store for breakfast.
420TEE
11-10-2003 06:58:42
Tom,
We moved to TN 3 years ago from CT after I retired. Daughter and 3 grand sons live here. Bought and rehabed a 150 yr old farm house on 4 acres of grass.Must have been nuts. Also a guest house and 12 stall barn. No animals except 2 dogs and a cat. Love to have some of your land to play with my tractor on. We actually live in the "city" of Coopertown but there is no PO so we use PV as our address. Have a nice day.
leon
11-09-2003 04:23:57
Memory tells me that it's foreign built, probably Germany, maybe Mexican, maybe Argentine, maybe Spanish. If German, perhaps it was originally marketed in Canada. It would have a close brother marketed here in the states. Just look for a 20 Series with the same number of cylinders in the engine and they will be basically, but sure not exactly, the same tractor. Some, but not all parts will interchange
david val
11-08-2003 23:26:46
this model does not exist in 'tractortips' neither in jd ag epc. is it a tractor? could be 1520 or 1630.
maybe someone just stuck a pair of '1620' decals...
there shold be a tag with trctor model and serial # either on rigt side of front support above front axle on european utility tractors or on the right side of the transmission case under the seat for north american utility or on the rear of the transmission case on row-crops.
david
Tom
11-09-2003 00:20:48
 Re: Re: Anyone ever heard of JD 1620? in reply to david val, 11-08-2003 23:26:46
Thanks, David. I think I'll visit the guy some time this week and look at the tractor. I'll try those locations and see if I can find a tag.
Thanks again,
Tom
