JD 830 PTO lever
Tom
06-05-2000 08:17:56
I recently purchased a 1975 JD 830. Sorry to disappoint anyone thinking this was about the good old 830. The PTO lever on the trator does notdisengage the PTO. The lever does not feel like it is attached to anything. To make things more interesting the 2 stage clutch seems out of adjustment. The clutch needs to be fully depressed before the PTO or the tranny stops. If I am reading the manual right the tranny should stop (allow shifting) when the pedal is half way down and the PTO should run until the pedal is fully depressed. Any advice on where to start would be appreciated. I can live with the PTO always being on, but the clutch adjustment is a show stopper for bushhogging. I realize the PTO will be turning any time I am in gear, I only mow a flat field where I keep the mower. I figure I can hook it up mow the field and take it off. Thanks
Tom in western NY
