John Deere 1951 B will not start
Darren
06-03-2000 17:48:37
When trying to start it, the cyclinders are filling up with fuel and soaking the plugs, any suggestions?
clooney
06-04-2000 04:57:32
 Re: John Deere 1951 B will not start in reply to Darren, 06-03-2000 17:48:37
Darren, we could use a little more information on your flooding problem, like how long you cranked it, how much choke did you use, will it start at all, when did it last run, when did the problem start. In the mean time pull both spark plugs & put NEW spark plugs in both wires then lay the plugs on the engine block then crank it with the ignition s/w on & see if it has a nice BLUE spark. If you don't have a good spark the problem probably is in the ignition system, if you do have spark it probably is in the fuel system or the way you are starting it. When you finally get it running make sure you change the engine oil, as the oil is probably diluted with gasoline by now.
Darren
06-04-2000 08:20:16
 Re: Re: John Deere 1951 B will not start in reply to clooney, 06-04-2000 04:57:32
We had left it in the rain for 2 weeks, after that it started, but then we was driving it down the road and it quit. When we try to start it gas is filling up the cyclinders and fouling out the plugs. We just put a new magneto on it and a battery and it still won't start. For some reasons gas is getting down into those cyclinders and we don't know what to do now. Any suggestions? Thanks.
clooney
06-04-2000 08:37:01
 Re: Re: Re: John Deere 1951 B will not start in reply to Darren, 06-04-2000 08:20:16
Darren, it still could be fuel or ignition related, just because you put on a new mag. doesn't mean it's getting spark. You should still check it for spark. Also pull the oil cup from the bottom of the air cleaner & see if there is water in it. If there is, try starting it without the oil cup on it, maybe the air cleaner is plugged with water & dirt. You might want to drain some gasoline from the bottom of the carb. & put it in a glass jar, then let it sit for a while and see if there is water in the gas. If there is water in the gas it will fill the cylinders and smell like gas but it won't run on that mixture. If there are drain plugs on the botttom of the cylinders (way up under the bottom of the cylinders) remove them & drain the cylinders to get the old fuel & junk out, then try to start it with no choke & the fuel shut-off turned off.....Keep us posted with your findings?
John T
06-03-2000 21:20:30
Darren, I sure agree with Ol zane there and a commom problem is the needle valve is not closing properly allowing flooding, or else a float can leak and sink to the bowl bottom again causing flooding. However, you say when starting??? Does this only happen when starting or if it just sits there does the fuel still continue to run and fill the cylinders?? The things zane and I talked about can allow continual flooding all the time, not just when starting. If it floods when starting only, it could be youre choking it way too much and/or your carb jets are set way too rich. Also, if the spark is weak, and you keep cranking and choking it, that can wet foul the plugs. Ol John T in Indiana
Darren
06-04-2000 14:19:10
 Re: Re: John Deere 1951 B will not start in reply to John T, 06-03-2000 21:20:30
We checked the float and needle valve appears to be ok. Just sitting, fuel does not flow, but when you try to start it cylinders flood. Loosened carb connection to intake and tried to start , fuel pours out at that connection and tractor does start for a few seconds. But when you tighten everything down it floods over again. Help!!!! Any suggestions, we're stumped.
zane
06-03-2000 19:00:36
Sounds like the carb bowl float is stuck with the needle valve open. Not uncommon.
