Paint removal.
AW
06-03-2000 17:31:58
I am reconditioning a grill For My John Deere LA. I have tried paint remover and the paint just won't come off. Anyone out there with a better idea? Thanks.
Ken Neubert
06-04-2000 14:54:58
 Re: Paint removal. in reply to AW, 06-03-2000 17:31:58
Try sandblasting.
Brian
06-07-2000 07:29:29
 Re: Re: Paint removal. in reply to Ken Neubert, 06-04-2000 14:54:58
Sandblasting works well. But watch your pressures. People are either for it or against it. I have had no problem. I have just a cheap wore out blaster. I have done 4 tractors with it. When it comes to sheet metal I typically don't blow more than 40-50 pounds. Cast and heavy sheet metal I like about 70-90 pounds. Like I said you should not have any trouble blasting at 40-50 pounds, it just takes a little more time.
Wind
06-07-2000 10:28:54
 Re: Re: Re: Paint removal. in reply to Brian, 06-07-2000 07:29:29
Another method I have heard about, but not actually seen, is using baking soda as a blast media. Something about the combination of the soda action and pressure seems to work. Not sure what pressure is used to blast with. Supposedly does real good at paint and rust, but does not erode metal or seals.
Leger
06-03-2000 18:18:08
Put part in the hot sun and spray with Easyoff oven cleaner, let it set for a hour- rinse off with water (power wash)
Gman
06-04-2000 20:27:49
 Re: Re: Paint removal. in reply to Leger, 06-03-2000 18:18:08
Leger sand grille with #80 emery cloth go to Auto Zone and get a quart of Aircraft stripper keep applying stripper as needed.while at Autp Zone get a little bottle of metal treatment and when you get all the paint of spray metal treatment on.I have just kept spraying Super Clean on to soften paint then use stripper. That Super Clean I'm told is purple Lye,I know it burns your hands. Sand blasting will errode your metal so be careful. Gman
