JD 730 batteries (polarity)
R Spicer
06-03-2000 09:24:36
I have had this tractor fora little over a year now. The batteries have gone bad in looking at them the previous owner had put two 12 volt units in parallel (+ to + - to -) instead of the 6 volt unit in series as original. When I pull the batteries I noticed the ground lead was on the positive terminal, not like a car or truck with it being the negative terminal. Is this correct, is the JD 730 a positive ground. Or did the previous owner mess it up and reversed the polarity. My service manual and owners manual do not spec the polarity of the batteries they both just warn against reversing them (kind of dumb huh). Any way can any one provide help to this problem.
Ron
DP
06-03-2000 09:27:52
 Re: JD 730 batteries (polarity) in reply to R Spicer, 06-03-2000 09:24:36
It was hooked up right. All two cylinder waterloo tractors wetre pos. ground. I don't know about the smaller ones.
G Taylor gas or diesel?
06-05-2000 00:22:13
 Re: Re: JD 730 batteries (polarity) in reply to DP, 06-03-2000 09:27:52
Is the tractor gas,diesel,12v or 24v system? All two cylinder Deere's were positive ground. Two six's in series are generaly less trouble than two twelves in parallel. When buying batteries bigger is better.
