48 A engine rebuild question
dale madsen
05-30-2000 10:46:36
I finally coaxed the pistons out of my stuck A and
it looks like the cylinder walls are pitted pretty deep. It is already .045 over and I am not sure if
going out to .125 will remove all of the pitting.
What are my options? Should I look for a used block (if so where is a good place to check?) or can it be bored farther or sleeved? I need some good news to make up for a depressing weekend after finding this.
David
05-31-2000 09:07:18
 Re: 48 A engine rebuild question in reply to dale madsen, 05-30-2000 10:46:36
Couldn't you sleeve and bore sleeves to fit .045 pistons. Not cheap, but may be best option. Also, check with Central Tractor (I forget the 1-888 #) my B had a cracked block with standard pistons and I got a nice, rebuilt sleeved to standard block from CT for $350 +$35 shipping. It was milled, honed and primed. I had some folks quote me that much or more for marginal used blocks. Also, check with Shorty Dear - he seems to have lots of parts at reasonable prices.
Frank B
05-30-2000 18:40:28
Dale, I found a good used block out of Wilson Brothers in Fredrickton Ohio. They seemed to have lots of parts there. They are about 1 hour NE of Columbus Ohio.
Spokerd1
05-30-2000 14:39:00
Dale you are looking at around $100.00 per sleve and then the cost of the pistons if you bore the block. You might check with Shorty Dear at [email protected] He has some real good parts. If he does not have it contact David Marlin at 417-589-2634. These might have what you are looking for in parts. Hope you better luck than you have had up to now
m fleeger
06-03-2000 19:09:23
 Re: Re: 48 A engine rebuild question in reply to Spokerd1, 05-30-2000 14:39:00
i have 2 blocks for your tractor one is standard bore we took this one out to put in a power block i could let it go reasonably cheap as i dont intend on using it again the other one is a little bit longer story if interested you can hotmail me
