40 to 420 swap
chuck
11-08-2003 12:31:42
my 40 block is cracked, can i put a 420 block in its place? what else needs to be changed?
thanks, chuck
ralph
11-08-2003 15:25:33
 Re: 40 to 420 swap in reply to chuck, 11-08-2003 12:31:42
how close are you to S W oregon ? i have 3 or 4 not cracked.n ralph
Wayne in Tn.
11-08-2003 12:42:31
Chuck, the two engines will physically bolt up in place of the other. The 420 will have a waterpump, and will be a larger bore, so you will need the complete 420 engine with head. Of course from a collector point of view, you will ruin the value of your 40 by putting a 420 engine in it. If you are just needing it to work with, you will have a noticable increase in horsepower with the 420 engine.
Clooney
11-08-2003 12:58:24
 Re: Re: 40 to 420 swap in reply to Wayne in Tn., 11-08-2003 12:42:31
Chuck, Wayne covered most of it.. I will add, you will need the later 420 radiator also as the hose sizes/hook ups are different..
ralph
11-08-2003 20:37:49
 Re: Re: Re: 40 to 420 swap in reply to Clooney , 11-08-2003 12:58:24
also the air cleaner and carb. hose and bracket that is on top of the head that the throtle shaft goes though. ralph
