JD 620 Power Steering-difficult to the left
Steve O'Dwyer
05-27-2000 21:18:18
Hello, My 620 is difficult to steer in the left direction, only. No grinding or noise, just difficult like there is no boost in that direction. Waiting on my shop manual from Deere, so in the meantime any help would be greatly appreciated. Many thanks...this is my very first tractor.
zane
05-28-2000 06:03:23
 Re: JD 620 Power Steering-difficult to the left in reply to Steve O'Dwyer, 05-27-2000 21:18:18
Adjust as follows: Remove the grill. At the top of the pedestal, (barely)loosen the four bolts holding the steering valve housing (mounted on the rt. side of the worm housing). If the steering wheel turns harder to the left, gently tap the housing to the rear and re-tighten the bolts. If it's harder to the right, tap forward. This is a delicate adjustment, and you will probably have to try several times to get it just right.
Why don't you go to your local farm supply store and buy yourself an I-T shop manual?
Steve O'Dwyer
05-29-2000 08:17:23
 Re: Re: JD 620 Power Steering-difficult to the left in reply to zane, 05-28-2000 06:03:23
Zane, Many thanks. The local ag store does not stock the I-T manuals, so I ordered one from Deere. Many thanks for your reply. That'll get me started.
Best Regards,
Steve
