620 weight
Andrew REinhart
10-13-2003 16:11:07
Does anyone know how much a 620 John Deere with a wide front end weighs? I need to tow one home, and I want to make sure it won't be too much for my 1/2 ton truck to handle. THanks
Loren from MN
10-13-2003 20:52:40
 Re: 620 weight in reply to Andrew REinhart, 10-13-2003 16:11:07
Just had to add some "stupid - stupid" comments to this. When Dad passed away, my son bought his 1950 Model A. I had to haul it about 35 miles to my place . Borrowed a friends 16" tandem trailor (no brakes). Pulled it behind my 95 Nissan Quest mini-van. Power was good. Braking were not. This was on country roads, but still not something I've ever do again. Put that 620 behind at least a 3/4 truck with trailer brakes !!!!! !
JDVan
10-13-2003 16:43:06
I want to reinforce what Clooney has provided. I have pulled a 1958 JD 620 with wide front end behind my 1996 F150. I do not recommend it at all. My 10,000 lb GVW dual axle trailer with brakes on both axles handled the load well but the truck struggled. I suspect the GVW of tractor and trailer was over 9,000 lbs as my trailer weighs 2500 lbs. I had a load leveler hitch on it too. I wouldn't have even considered it w/o that being used. My trip was about 100 miles and I did not feel comfortable the whole trip. If you do it be very careful and leave lots of room ahead of you. Be careful
Bill
10-13-2003 16:36:07
mine was 6150 at the local tractor pull the other day i had it on the scale and its a row crop with no extra weight so yours has got to be about 6500 like clooney said, hauled it on a 10,000lb trailer with a 1 ton chevy 4x4 did real good.
Clooney
10-13-2003 16:28:23
Andrew, probably every bit of 6,500 lbs. That will be quite a load for a 1/2 ton truck. ~You will need a good trailer with 4 wheel brakes. A [2 axle brake] equipped 7,500 lb axle standard car hauling trailer won't cut it.
~I have pulled a 620 wide with a 1/2 ton truck before but the trailer must be able to take most of the weight. Even then it isn't a good safe feeling. ~Remember the tractor & trailer together will weigh 8,500 lbs plus so stopping that with a 1/2 ton truck will be wishful thinking if the trailer doesn't have 4 GOOD functioning brakes..
