Battery drain
Boyd
05-27-2000 04:01:49
I have a 1949 JD -M, org.6 volt- pos. ground
system & I can't keep my battery charged.I've
replaced the battery & had my geneator rebuilt,
there is no detectable draw between post & cable
but when I lift the ground (pos.) cable while tracor is running, it cuts off??? PLEASE HELP!
Boyd
05-31-2000 04:59:32
 Re: battery drain in reply to Boyd, 05-27-2000 04:01:49
Thanks guys, it seems that my problem was the wiring somewhere between the gen. & the regulator,
seems to be working now after cleaning & reconnecting terminals. Thanks again,
Boyd
Boyd
05-27-2000 12:48:57
Thanks so much for the help, it may be Monday before I can get back to the tractor but I'll post a follow-up to let yall know how it turned out!
John T
05-27-2000 10:48:00
Boyd, Unlike with some alternators, when you disconnect your battery as you say, it should kill the engine. If the geneartor is good and all wiring is properly connected, the voltage regulator could be your problem. It has a cutout relay which, if not closing, never allows the generators armature output to be conected to the battery terminal. Also, if its not allowing the field winding to get to frame via the internal resistors, the gen will not charge properly. There are ways to test that but its a little difficuilt to explain it all over the web here, so you may want to take the generator and regulator to a good old fashioned generator shop and have the combination checked out. I assume the gen belt is tight and if it has an ammeter its good and all the wires are connected, you may want to insure the battery termiunal wire out of the regulator actually has a good connection to the battery, often through the starters connection terminal. Ol John T Engineer in Indiana
clooney
05-27-2000 10:30:19
Boyd, the information you furnished is not enough for a complete diagnosis. It sure sound like your generator isn't charging though. Things to check are, is the field wire connected from the "F" on the generator to the "F" on the regulator, is the "ARM" on the gen. connected to the "ARM" or "G" terminal on the reg., is the "BAT terminal on the reg. connected to the battery negative at the battery or starter & not grounded? Take a volt meter or 6 volt test light & make sure the "BAT" terminal on the reg has 6 volts with the engine off, if it doesn't, post back or find out why. While you are there you might as well polarize the generator, (with a charged battery in the tractor momentarily connect a jumper from the BAT to the ARM or G terminal on the regulator) that should properly polarize the generator. If the BAT terminal on the reg. does have 6 volts start the tractor & put it on fast idle then connect a jumper from the "F" on the generator to ground (does it charge now?)If it does & all the wires are hooked up correctly then you probably have a bad regulator. If you post back with more information or have questions about these procedures I can be more specific about finding your problem.
Charlie B
05-27-2000 06:40:34
We had a similar problem on our 3020. The starter was shorting out.
