JD400 Kohler Engine Timing Help
Anthony Warren
11-08-2003 09:50:37
Hello,
I have a JD400 Lawn Tractor with a K532QS Kohler Engine on it. I have drawn the marks on the Flywheel as in accordance with the service manual to check for timing. The engine runs fine, but, according to my timing light, the engine is not correctly in time, as I cannot see the mark through the timing hole at the top of the engine.
Is there another way to check for timing rather than using the light, or do I need a special timing light for this engine, or am I just doing something wrong?
Thanks in advance.
buckeye al
11-10-2003 11:28:32
 Re: JD400 Kohler Engine Timing Help in reply to Anthony Warren, 11-08-2003 09:50:37
I agree with 720 D. Not much room there & not easy to see but that's the best way. Be persistent with it it will pay off.
720diesel
11-08-2003 18:40:50
We use a timing light,but the mark on the flywheel is very hard to see through the hole ,but it can be done.Good luck and I hope you get it timed right!
