How Much Compression!!!
Bill {Antique A
05-24-2000 12:29:24
How much compression should my 41' Hand Start B have? Thanks Bill {Antique Acres}
clooney
05-24-2000 17:29:54
 Re: How Much Compression!!! in reply to Bill {Antique Acres}, 05-24-2000 12:29:24
Bill, with the engine warm & the carb wide open the compression should be 70 psi at cranking speed. If it has over sized pistons, gas pistons or a lot of carbon build up it will be higher. 60 psi would probably be the low limit.
