3010 Wheat-sters Diesel
Mike
05-03-2000 19:17:42
I'm looking at a JD3010 with low front end (sits low to the ground) the owner says its a "wheat-sters" model (or thats what it sounds like he's saying). fresh overhaul with new clutch,average rear tires,new front,paint 50%,top sheetmetal rough. priced at 2,500 with bushog. Anyone ever hear of this model?
Mike Aylward
05-04-2000 05:09:22
 Re: 3010 Wheat-sters Diesel in reply to Mike, 05-03-2000 19:17:42
Mike, are you sure it's a standard? It sounds like it could be a row-crop utility with the lower front end. Let us know the serial number and we can tell you which it is. Either way, at $2500, if it indeed has had all the work done to it the owner said ("verify"), then it sounds like a good deal. Hope this helps. Mike
Nate
05-03-2000 19:48:50
They call it wheatland or the correct term standard. Check out the auction under tractors. A standard with a loader is being auctioned off.
