I Need Help to ID Filters
Bruce
05-02-2000 22:42:33
I'm cleaning up a deceased uncle's barn. There are many JD filters, but I do not know which filters fit which models. I've tried to cross-reference from catalogs, but with no luck. I would sincerely appreciate any help in determining the correct applications. Thank you! ===== ===== ===== ===== ===== ===== ====
JD# AR28072 Oil Filter Element
JD# AR26350 Oil Filter Element
JD# AR75603 Oil Filter Element
JD# AR28271R Oil Filter Element
JD# AR45097 Fuel Filter
JD# AR44077 Diesel Fuel Element
McC
05-03-2000 00:17:42
 Re: I Need Help to ID Filters in reply to Bruce, 05-02-2000 22:42:33
AR26350 Engine oil filter-3010/3020-4010-4020-A-B-20 & 30 series 2 cyl. tractors among others. AR75603 Hyd & trans filter for 3010/20 4010/20 Most 30 and 40 series utility tractors.
AR45097 Spin on fuel filters for 3010/20 and 4010/20.
AR44077 Cartridge type fuel filter for 3010/20 & 4010/20 tractors. That is all I have right now. Let me know if I can be of any more help, and I will research it some more.
Bruce
05-03-2000 06:56:06
 Re: Re: I Need Help to ID Filters in reply to McC, 05-03-2000 00:17:42
Thank you for your prompt reply. Your help is greatly appreciated!
