Hydraulics, and tran. on 4440 ps
danny collier
05-02-2000 18:46:01
power lift leaks off, and tran slips in low gears after tractor warmsup, what should i look for to fix this problem.
twopop
05-02-2000 19:52:58
 Re: hydraulics, and tran. on 4440 ps in reply to danny collier, 05-02-2000 18:46:01
You really need to have a repair manual,as it explains the tests you need to perform on the trans to determine what is causing it to slip.There are several possibilities.The trans.hyd.pump could be bad as also the 0 rings in either the front or rear clutch pack,the powerlift could also be leaking down due to several reasons
