3pt bleeds off
David
11-08-2003 05:07:48
I've got two 2020s. When shut off, the '67 will hold 1000 lbs on a boom pole for days w/o dropping an inch, but the '71 will bottom out overnight. Is this serious and what needs fixed? thanks
David
11-08-2003 18:51:41
 Re: 3pt bleeds off in reply to David, 11-08-2003 05:07:48
Tightened the drop valve all the way and it still went down. If 1 inch per 5 min is standard, then I won't worry about it. Thanks for the advance. David
G-MAN
11-08-2003 12:21:31
I wouldn't lose any sleep over it. Pretty much ALL hitches will settle down over a period of time, as they are operated by valves that will allow oil to leak past them over time, just due to the fact that they're machined parts that must have clearance. The only way to get around it is by using a load-check valve, and even those allow leak-down over time. There might be a spec for testing it, but I'd say that if it takes all night for it to settle, it's well withing spec. Even a brand-new 8520 has a hitch leak-down spec. I believe it's a maximum of 1 inch in five minutes with warm oil. Anything less, and the system is considered normal. It IS a good idea to lower any load if the tractor will be parked for a period of time - it's safer, and saves stress on the hitch and tractor components.
david val
11-08-2003 09:20:51
leakage in the hitch hydraulics can be in the cylinder due to bad seal or most likely,scored cylinder, leaking lowering valve or leaking cylinder inlet check valve. a careful repair of the cylinder assembly can probably improve the condition but the possibility of some leakage (and consequent hitch lowering) still exists.
if the hitch only drops overnight, i don't think anything should be done.
btw, to check weather the lowering valve is leaking, you can tigten the rate of drop valve under the seat tight. if the hitch don't lower or takes loger to drop- the valve is leaking.
david
old
11-08-2003 08:38:22
Its probably a small leak in a line or the cylinder. On the other hand every tractor I have does the same thing, other then my oliver 77 which has a home made 3 point. I was always told not to leave anything in the up position on a 3 point becauce its hard on them, don't know if thats true but it sure is safer. You never know when some body will mess with a lever and if you have kids around it make since to drop the equipment. Well thats my 2 cents worth hope this helps a little
