3020, powering out while driving in down road?
Nic C.
05-02-2000 18:24:09
We have a JD 3020(gas) and I was going down the road the other day in 8th and it just powered out and slowly killed the motor all of a sudden? The rear end is full of hy-tran. It did it twice trying to get home? Could it be somthing with the hydraulic pump, or bearing in the rear end? (It was just like you powered it out while plowing!)
twopop
05-02-2000 19:57:45
 Re: 3020, powering out while driving in down road? in reply to Nic C., 05-02-2000 18:24:09
Had a 4630 do this,it spun 3 rod bearings.I suggest you disconnect the main hyd.pump and see how hard it is to turn the motor over by hand.drain the oil out of the motor and then feel around for metal shavings,thru the drain plug
