JD60 Oil pressure fuel shut off
Rich
04-29-2000 11:21:28
What is the best way check if the diphragm is leaking gas into the engine oil on a JD60 through oil pressure fuel shut off. I have not found the engine oil to be deluted but I want to be sure it is not leaking. If the oil line is disconnected from the shut off housing with the engine off and no gas leaks out of the oil opening would that be a suitable test.
clooney
04-29-2000 12:04:41
 Re: JD60 Oil pressure fuel shut off in reply to Rich, 04-29-2000 11:21:28
Rich, it sounds like you have a good way of testing it. If you are really worried about gasoline getting into the crankcase you should replace that diaphragm now, before it leaks. They have a tendency to leak without notice. Or put a shut-off valve in the oil pressure or fuel line. Also don't use any gasoline with alcohol in it, as alcohol tends to destroy non-resistant rubber parts.
