Salvage price for 47 A
John in Dry Ok
04-29-2000 10:33:14
Have a chance to buy a 47 A for salvage. It has stamped wheels, Good rear tires, 14.7 X 38 but not a matched set. Round spoke front wheels, hand start, block and head are bad and no it is not a Heisler. Tractor is complete with the head and block removed. They are asking $500.00. What do you think?
John in Dry NE Oklahoma
Pappy
04-29-2000 22:22:31
 Re: Salvage price for 47 A in reply to John in Dry Ok, 04-29-2000 10:33:14
John---consider where it is located. Obviously, buying it close to home is beneficial and can be worth many pesos in hauling costs.
Roy
04-29-2000 20:37:14
There is salvage yard south of me in Burlington, KS that has several complete A's that he's asking between $125 to $300 apiece for. They range in conditions of looks like that haven't ever ran to just needs some TLC. I bought my 43 A from him, that turned out to need a sleeve because of a pin hole in the cylinder wall, for $500. At the time it ran good and only needed the idle passages cleaned and a new tire, other then that it was field ready.
jess
04-29-2000 23:18:00
 Re: Re: Salvage price for 47 A in reply to Roy, 04-29-2000 20:37:14
WOW!!!!I'll take 2!!
04-29-2000 17:32:37
I double checked the serial number and you are correct, it is a 1943 model. SN# 525268 Thanks for the advice, I will make a low offer and see if it will fly.
John
Jim
04-29-2000 16:50:04
I have a freind that just bought a running A on a sale for $900.00 and even had a square tube wide front ,around here the A you discribed would bring around a $100.00 .
Scott
04-29-2000 19:46:52
 Re: Re: Salvage price for 47 A in reply to Jim, 04-29-2000 16:50:04
hey...buy me a tractor...!!!!! !!!
Jim
04-29-2000 23:14:32
 Re: Re: Re: Salvage price for 47 A in reply to Scott, 04-29-2000 19:46:52
No way I buy them and send in for old iron.
Jim
04-29-2000 23:18:50
 Re: Re: Re: Re: Salvage price for 47 A in reply to Jim, 04-29-2000 23:14:32
No I buy them for my self. Last week I bought a running 60 for $500.
Mike Aylward
04-29-2000 15:23:42
John, I hope you don't think I'm trying to throw cold water on your plans, but around here (northeast Missouri) an A like that with a bad block and head would go for less, unless it has a good, uncut hood and a good carburetor and magneto, etc. I would guess the carburetor is probably bad, too. Are you sure the wheels aren't cut-offs? And with hand start (and the spoke wheels) it is more than likely older than a '47. Unless you need some of the parts off of this tractor, do this with your eyes open. Just my humble opinion, worth exactly what it costs..... :-) Hope this helps. Mike
clooney
04-29-2000 12:11:19
John, that is a good buy on a parts tractor. Unless it has a special s/n or some other special value to you it will probably cost you more to repair than you can buy a good running "A" for though. If the ft. wheels are in good shape they are worth almost the asking price of the tractor.
Mike
04-29-2000 14:44:06
 Re: Re: Salvage price for 47 A in reply to clooney, 04-29-2000 12:11:19
I don't know about the front wheel value, but at 500 you can part it and do ok. Still if I was buying it, while I'd give 500 for it as long as I had a few parts sold before I bought it, I think you are on the the high end of price range for a parts tractor that has major medical wrong with it. My 2 cents worth , Mike
