3020 12 volt system
Charlie B
04-27-2000 06:45:19
We installed a 12 volt system on our 3020 last year. We kept the 2 twelve volt batteries. When it's time to replace the batteries, is it better to go with two sixes? What about a single twelve?
G Taylor keep the 24v parts
04-28-2000 20:28:49
 Re: 3020 12 volt system in reply to Charlie B, 04-27-2000 06:45:19
Keep all the 24 volt parts. In the future you will be glad you did. A pair of six volt batteries in series rather then two twelves in parallel avoids slight differences in resistance causing unbalanced charging & loading. One battery may do most of the work in a parallel system.
John T
04-27-2000 13:06:24
Charlie, GENERALLY two sixes in series is better than one 12 BUT ONLY IF AND BECAUSE you have more lead and more acid and more plate density and plate surface area and a greater total amp hour capacity. For example, if the two sixes are very wimpy cheap low Amp Hour Batteres, while the 12 were a super heavy duty, the opposite could be true. Its amp hours and lead and acid and more plates is greater in two sixes than a single 12 is why they are USUALLY (not always) better. A battery stores energy and the bigger amp hour units with more lead and acid and plates store more energy. There may be some confusion below, two batteries in series add the voltage, but the amps that can be delivered is no greater if you stick two in series. However, if you connect two in parallell, the voltage stays the same, but the amps capacity is doubled, half of which can be delivered from each battery. Now, the amp hour capacity is additive, but not the amps of what either can deliiver if two are in series, that does not double. Energy is Volts times Amps, so at twice the voltage with two in series, the same current flow as one is still delivering twice the energy to the starter, since its at 12 not 6 volts. Ol John T Elecrical Engineer in Indiana
twopop
04-27-2000 06:52:58
Two sixes will give you more cranking power than 1 twelve
jess
04-27-2000 07:23:45
 Re: Re: 3020 12 volt system in reply to twopop, 04-27-2000 06:52:58
are 6 volt batterys cranking power rated the same as the 12V
twopop
04-27-2000 12:03:00
 Re: Re: Re: 3020 12 volt system in reply to jess, 04-27-2000 07:23:45
if you use two 6v batteries in series rated at 800 cold cranking amps,they will deliver 1600 cca to the starter. even if you use two 800 cca 12v batteries in parallel you will only get 800 cranking amps to the starter
