A or B, problems to look out for when purchasing?
aaron
11-07-2003 15:10:40
Hello,
I have some experience with IH, but none with John Deere. I am going to an auction soon where there is John Deere A & B on consignment. I have zero experience with John Deere but would like to try one out for fun. They are both styled, narrow fronts. What should I look for as far as mechanical integrity. What is prone to be wore out or broken on the John Deere.
Thanks a bunch,
Aaron
Slofr8
11-09-2003 18:06:12
 Re: A or B, problems to look out for when purchas in reply to aaron, 11-07-2003 15:10:40
You could make sure the splines on the clutch side of the crank are good. I've seen a few that were wore and someone shimed the drive disk with tin strips.
truckman21
11-08-2003 19:54:09
The older A's and B's are fairly simple and easy to figure out. Sheet metal is important, as replacements are quite expensive. Otherwise, they just seem to be a somewhat high-priced tractor, but very enjoyable.
GeorgeH
11-07-2003 17:25:02
Look at axle where goes into casting. If leaking 90 wt fluid and it's brown (like rust) might mean new bearings and/or seals. Not terribly tough job but the bearings are not cheap.
My $.05 worth.
old
11-07-2003 16:49:36
Most of them old As and Bs didn't have much problems, at times the cluth can be a problem but its a easy fix. Your biggest problem will be getting usto the pop of a johnny. The old Johnnys have a lot of pull for 10 yards or so and there good tractors. Hope this helps some
