Daniel, theres nothign that sounds better than a well tuned G. Unfortunately, without a good load on the tractor or at least beign there seeing and hearing how she performs, I cant tell you exactly how to set the carb as you asked (they are all a lil different), but can give you some guidelines for adjusting the carb tops load and idle needles. There are different ways to adjust them and different for different tractors dependign on the engines condition and the ignition quality, so just consider these as guidelines. Hopefully, you will get several methods and opinions on how others set theirs, but this works for me. 1) The initial rough in top load and idle needles are set by closing down then opening out: Load Needle: 3/4 to 1 turn out. Idle Needle: 1 3/4 to 2 turns out. 2) Adjust the idle needle at slow idle to where shes not too rich (not too much black smoke) but idles slow and smooth and even. I usually at slow idle screw them in till she starts to cut out, then open back out till shes smooth but not so far she blows excess black smoke out the stack. 3) Its best to adjust the load needle under a load like on the PTO or belt pulley. As you open it too rich she will black smoke and may load up, then screw her back in just a tad. Or under load lean her in till she just cuts out then back out a tad. If you have no load, I set the throttle wide open and richen the load needle till she just black smokes then back in a tad, but you really need a load, cuz that method may not allow enough gas if under a load and she may hesitate when you crack the throttle. 4) They need to be both adjusted so when you crack the throttle open up from idle, she dont hesitate or falter or cut out or sputter or delay i.e takes her gas and revs up. If set too lean, that (cutting out) can happen. Generally, if set out too far rich she black smokes out the stack but if in too far lean, she dont get enough fuel and may sputter or cough or die or cut out. I set both of them as lean as possible to avoid excess black smoke out the stack, but rich enough to have power and take her gas when you crack the throttle. At idle the idle stop screw needs to work up against the post spring. Any vacuum leaks like the carb gasket or throttle shaft bushings or manifold cause poor idle, so fix any of those before tryign to get a sweet smoth slow idle. If she dotn idle smooth, post back for more troubleshootign tips. To run right and idle slow n smooth shes gotta have a good strong spark also and decent compression, but post back if you need help with ignition problems. Make sure the gas is clean and fresh and water free and you might check the air cleaners lower bowl to see it has no water and is clean. Make sure the choke butterfly plate is tight on its shaft and stays in place relative to where its set externally. Also be sure the governor rod to the carb is set right and she works smooth and free and theres no cotter keys binding up the linkage. I hope this answers your question and its just one method (others have different methods) which isnt right for all tractors but is a good place to start. Post back or e mail [email protected] with any questions or problems and let me know what you find. If she wont idle smooth, also let me know, you may have other internal carb problems. Best Wishes and God Bless ya Daniel John T Nordhoff in Indiana
