450 hydra push update/ G pto parts needed
Mike
04-26-2000 09:30:29
Never found out if the G would handle the spreader or not, although the hydraulics did cycle through. The pto is bad, which I did not realize until I hooked on to the spreader. The parts I need are not availible from deere anymore, so now it's time to start hunting boneyards. I have my parts book #'s if anyone wants to try and help me. Thanks, Mike
Gman
04-26-2000 13:37:19
 Re: 450 hydra push update/ G pto parts needed in reply to Mike, 04-26-2000 09:30:29
Mike these pto's are fairly simple,what kind o parts do you need. I know you didn't break a shaft,all gears are splined you might need to replace a bushing or a seal.I have a complete rockshaft housing powertrol and all,shaft is 1 3/8 most early "G"s are 1 3/4 let us hear from you. Gman
Mike
04-27-2000 11:25:03
 Re: Re: 450 hydra push update/ G pto parts needed in reply to Gman, 04-26-2000 13:37:19
If you have a jd G parts book it is on page 83. I believe I need either part #F 256 R (key #57) or F 248 R (key #43) I haven't pulled the pto yet, but I am guessing it is one of them. Wenggers has both parts, but if you want I'd buy them from you instead. I will probably pull the pto out sunday to figure out whats wrong. Thanks, mike
