Since the lights are divided equally between the two 12 volt batteries, is it safe to assume that the lights on the left side of the tractor are run off the left sided battery and vice versa for the right side? I have a 4020 with a light on each fender, lights on extensions just anterior to the instrument panel, sticking out on each side, a tail light mounted on an extension off the middle of the rear of the tractor, and a flood light on the left fender. Here is the problem: The left front fender light works great, but the front extension lights and the right front fender light are very dim. The rear lights don't work at all. Another strange thing, the light that burns the strongest is only pulling about 8 volts. The dim lights are pulling only 4 or 5 volts. Are there shorts in the three dimly lighted lights? Any help would be appreciated. Maybe I just need to replace all the wiring harnesses, eh? I would appreciate any help on how to trouble shoot this electrical system. Are there any written resources? Are front "extension" lights supposed to be the bright lights?
