JD 2-BOTTOM PLOW
Courtland
04-25-2000 17:29:22
I have a plow that has a number on the cross brace between the two beams. That numer is 15833 and is just above the words John Deere. Does anyone know what number and year it is? Both plows are facing the same direction and the wheels are steel.It looks like the No. 52 plow. How about books, manuals etc are they available or does any one have electronic files available.??
Bob
04-25-2000 18:47:46
 Re: JD 2-BOTTOM PLOW in reply to Courtland, 04-25-2000 17:29:22
This is a number 40 plow, originally made by John Deere especially for the Fordson tractor. first made in 1918 different versions were available thru 1923. It may look like a #52 at first glance but you will notice that the beams are made from flat stock rather than the forged rounded I beam shape of the 52 and many of the later John Deere plows. As far as I know you might be able to get an operators manual at a swap meet or directly from JD but there were no parts books printed separately at that time. The list of part numbers and illustrations was printed in the Plow Works Catalog issued every three or so years mostly for dealers as they were more than 1000 pages thick and have a TON of info in them. I hope you are restoring this plow there aren't too many left at least in my area. Hope this helps.
Bob
04-26-2000 03:37:08
 Re: Re: JD 2-BOTTOM PLOW in reply to Bob, 04-25-2000 18:47:46
Here's some updated info: this could also be a 40C plow which is just a later version with a slightly different hitch and lift clutch. also it is a 14" size it was made in 12" also. This plow was manufactured through 1934. Bob
Courtland
04-26-2000 05:38:10
 Re: Re: Re: JD 2-BOTTOM PLOW in reply to Bob, 04-26-2000 03:37:08
Thank you. I plan on using it this spring. Good Idea?? It's in great shape too....
Bob
04-27-2000 19:02:21
 Re: Re: Re: Re: JD 2-BOTTOM PLOW in reply to Courtland, 04-26-2000 05:38:10
Plows are for plowing! I cant think of any way to enjoy an old plow more than tipping over a field with it.
