2020 clutch shaft question
Darin IN
08-02-2009 21:00:37
I've split my friend's 2020 gas, 2 stage clutch, no reverser tractor. It's almost ready to go back together, but I've got a question about what I'm seeing. The clutch shaft isn't on center with the PTO shaft. The clutch shaft is laying on the bottom of the bore of the PTO shaft. It looks like this will cause more trouble than I'm already expecting when trying to align things when going back together, since the shafts are not on the same centerline. Should there be a bushing in there? I realize that once everythings back together, the pilot bearing will support the other end and center the shaft inside the bore. I haven't found anything in the IT manual about this yet. JDparts showed a seal that might serve this function, but I'm not sure. Has anyone ever had this same problem?
