John Deere 730 gas- power steering pump removal
Hans Horst
04-24-2000 08:55:18
I would appreciate information on removal of the pump for rear shaft seal replacement. Power steering fluid is migrating from power steering pump, to engine crankcase. Do I have to remove the radiator, as the dealer says? I expect I have to replace the seals at both ends the input shaft, is this possible without pulling the rad out?
clooney
04-24-2000 09:23:08
 Re: John Deere 730 gas- power steering pump removal in reply to Hans Horst, 04-24-2000 08:55:18
Hans, the book says it should come out without pulling the rad. BUT!!! I have never been able to get one out without moving the rad. forward some. Be very careful that you don't pull the rear fan shaft out of the rear coupling, if you do you will remember the experiance. Hold it to the rear when you pull the pump. (slide the pump forward just enough to see the front coupling then push it to the rear when pulling pump forward). If you can get the fan off in the tractor ( which I doubt) it will probably come out OK. To me it isn't worth risking putting a hole in the rad. If you try to remove the pump without moving the rad. forward put a piece of tin between the fan & the rad. core to protect it. Good luck.
Jack
04-24-2000 09:12:02
Hans,I put my 70 gas back together by taking the fan shroud off and flexing the blades on the fan.You really need 2 people to manuver it out because it is really close to the radiator,but if it is similar to a 70 it can be done.later Jack.
