At the risk of ??
LARRYG
04-23-2000 12:16:02
At the risk of soundimg stupid, What is a flat head " G " ??
Gman
04-25-2000 12:18:31
 Re: At the risk of ?? in reply to LARRYG, 04-23-2000 12:16:02
Larry A "G" flat head will have no combustion chamber also it will have casting # F48R or F485R the later is the better of the two heads,more coolant better valve positioning,also there is a F551R head for styled "G"s some call the cylone heads,then there's the Kansas "G" head,flat huge valves and spark plugs in head,these are extremely qualitiy heads. Later Gman P.S when you refer to a John Deere "G" you should always put Quotation marks fore and aft of the "G" sort like reverence.
Gord G
04-24-2000 13:43:57
Always remember that a question is only a stupid question to somebody that THINKS he knows everything. And that changes the first time he asks one!!! I have lived what seems to me to be a few lifetimes and I still believe that you have not lived a full day unless you learn at least one more thing everyday and since I got the internet and found all these discussion boards, I have learned A LOT!!
Gord
STMTS
04-23-2000 19:26:43
Its a G with a flat cylinder head from or on a unstyled G. This means the head has no chambers it is flat.A styled G has a thick head that has chambers cast in. If you put a flat head on a styled block it boosts the compression quite a bit
jr
04-23-2000 19:23:56
does not a combustion chamber in the head
jr
04-23-2000 19:28:05
 Re: Re: At the risk of ?? in reply to jr, 04-23-2000 19:23:56
does not have a combustion chamber in the head
