J.D. 50 Engine oil in trans
Ben .So .Tex
04-23-2000 07:30:58
I have engine oil getting into the transmission ,What am I going to need to pull this tractor down, any special tools, and what should I becareful of during the tear down? I
Rob
04-23-2000 07:55:11
 Re: J.D. 50 Engine oil in trans in reply to Ben .So .Tex, 04-23-2000 07:30:58
If you don't already have one, I would suggest a service manual. But you will at least need to pull the right brake assy. and the clutch, belt pulley and reduction gear cover. The right side main bearing assembly has two seals back to back that you need to replace. Be careful when you pull the bearing housing off, there is an oil line from the pump connected to the housing to provide oil to the bearing, you'll need to remove the top cover and go into the crankcase to disconnect this oil line. Also I have heard that sometimes the gasket between the bearing housing and the main case will leak. It's not a terrible job, but it will take some time. Good luck.
